Rekluse 3.0 EXP setup (2011 EC 300)
kdxkid
Hello,
Any advice on what spring combo to run in the Core EXP 3.0?
Also, any advice on running CR frictions? They are a bit thicker (around 3 mm) - I am not sure if I can use 7 of these, or if that will be too thick.
Here is my thread on this with photos and detailed specifics. Go to post #15 for details, then posts #42,#46 and #47.I have never had a problem with this setup and I am still using it now.
http://www.gasgasrider.org/forum/showthread.php?t=15126&highlight=Cr+clutch+pack&page=2
I just read that (and the link regarding the honda steels / fibers). Both don't deal with the CORE EXP 3.0. Can I ask why you switched over to the honda steels / fibers? Also, why did you go out and buy the rekluse basket without first trying your GG basket w/ the rekluse core EXP?
What I am really after is what springs are people using the their CORE EXP 3.0.
I use the ones that came pre-installed with the EXP 3.0 kit. Suits me fine on my 200
Me too. The Rekluse basket is probably not necessary but it is much stronger. There is better availability of Honda clutch plates and the price is cheaper.
