Removing kickstarter
biggstr6
Bronze Level Site Supporter
Used a little heat. I've never seen a kickstarter get so stuck before.
How do you delete a thread ?
Try a small puller but put a nut or washer on the shaft to protect the threads.
Look at the little box at the bottom left of the topic page. It's called posting rules. It doesn't say "you may delete your own threads", so this function has been reserved for moderators. The most you can do is edit the post to remove content.
All forum software has permissions set up by the board administrator. The admin decides which ones the users will have.
I got it off with a little heat. It was on there pretty good though .
Thanks , I was looking every where and didn't see a delete option.
