Removing wiring
Bandit9
How much of all the wiring can be removed on a kicker 12 XC300? I only need a kill switch.
Not enough to make any noticeable weight savings. The bulk of the wiring is for the ignition system and required. You could remove the headlight regulator (which is tiny and light), you could remove a few short wires for the head and brake light. That's about it really.
