Anyone got a source for reasonably priced replacement rads? The OEM ones are a wee bit pricey to say the least. It would be about $500 to replace the pair.
I bought my 2010 EC250F used and both rads are bent and crushed from the previous owner. I tried to straighten out the mounting tabs and ended up popping a leak in the left rad.
If I could find a reasonably priced set, I'd replace both but $500 is kinda pricey.
The crossover list shows that GasGas use KTM rads, but which ones?
I will def be buying rad guards after this.
