You could buy some ODI Lock On grips which come with a replacement throttle tube everytime. No need to use glue or wire on your grips anymore. I have these on my bike..
They do but it is a bit more expensive. Nobody seems to specify one for GasGas. I'm still trying to figure out if the KTM models use the same cam size as the GasGas.
I put this on the bike along with a motionpro throttle cable, 10-3000. I'm not sure if it's due to an undersized cam or not, but there was excessive slack in the throttle cable with this installed which there is just barely enough adjustment to get rid of.
My bike is a 2010 model as well but it's a 300 2 stroke so the cam would be different to yours. I think that the throttle assembly is fairly similar to the KTM one so I think that it was Cam D that fitted mine perfectly. I would have thought that yours would have worked with Cam A. Maybe someone else that owns a 4 stroke might be able to help.
