Rieju ranger horn wiring?
Bigboresrule
Bought a 2021 300 ranger the switch on left handle bar shows a horn button along with turn signal switch. I believe behind head light I've found the turn signal wires but can't locate the horn wiring and have pulled the tank to see if the wires are there. I've found a pre ktm gas gas wiring diagram and see the horn and turn signal shown. The Rieju manual I got does not show any wiring nor mention horn wiring. Any one been down this road?
The entire switch wiring goes to a plug behind the headlight.That will have the starter ,indicators ,horn ,headlight high/low.The owners manual clearly shows tall this
I will check page 16, looking at switch I believe a gray and a red wire come from switch go behind headlight area into the main wiring loom. I was not able to see them come back out of harness until the battery area. I clearly see 4 wires behind headlight that would appear to he for the front turn signals. I will check further as this should have been an easy find.
Yes page 16 does clearly show the wires. Appears I had 2 pdf files for rieju and one was one page 21 but not very defined (I may delete this pdf and keep the other one) the issue is finding the wires. I will did into this today with the page 16 wiring and color code.
Found the gray and green/yellow horn wires hidden tucked in with large wiring bundle near the head stay. All hooked up now with decent horn.
