Does anybody use rotella or any other cheap tranny oil? I am going to try rotella. I change every 5 hours anyways. Also rotella T4 is JASO DH2 MA MA2 certified so it should be fine for a wet clutch?
I find ATF a bit too thin and Rotella T6 a touch thick. While this will make some member's heads explode, we have been mixing 50/50 ATF with T6 for years and it has worked great in 8 older GG bikes.
I run Rotella T6 in my Yamaha FJR1300 and change on 5000 mile intervals. I add about 1/4 cup (to the 1 gallon the FJR uses) of STP oil treatment and the bike shifts like silk. I ride 2 up 95% of the time and tow a Bushtec trailer with it. No clutch or power delivery issues ever on the bike. I am over 56,000 miles on the clock. The cams show no wear and look good at each valve check.
I have a gallon of T4. It is 15w40 and I don?t think it is full synthetic. Will I be able to use this with short oil change intervals or should I ditch it and get T6?
Try the T4(regular oil) and see how your particular clutch performs. If you like it don't waste your money on T6(full synthetic). I've had six gassers and the clutches were all different - some did fine on the thicker T4, some worked better on the thinner T5 which is a semisynthetic, and my 07 gasser had to have T6 which is the thinnest viscosity of the three to keep that clutch from dragging.
In the UK I use triple qx 5w40 fully synthetic car oil. If you look at the specs it's basically the highest spec car oil you'll get before they add friction modifiers. I can't find a direct replacement for rotella t6 sadly .
I think that the Shell Rotella is similar to Shell Helix. Beta riders in the USA use the Rotella T6 instead of the nasty pond water that Beta fill their gearboxes with at the factory. The Triple Qx is good stuff and I know a few people that use it with no problems in 2T boxes.
I go to a local bulk oil supplier and get UTTO (Universal Tractor Transmission Oil) for my older Yams. Never had a problem and it is about $90 AUD for a 20 litre drum.
Same spec as mineral trans oils, suitable for use in wet clutches.
