gasgasman Super Moderator Staff member Dec 2, 2012 #1 Anyone have any rubber rim straps they want to get rid of? Need 21" and 18". I run Bib Mousses and duct tape just does not hold up to the Bib lube. Thanks Girard
GMP Active member Dec 2, 2012 #2 Girard, Try HV electrical tape, the rubber stuff that sticks and bonds to itself. There are also variants sold as "Rescue Tape" for fixing radiator hoses, etc. Mcmaster has this. A couple layers should work fine.
gasgasman Super Moderator Staff member Dec 2, 2012 #3 Glenn. Never thought of using that. No glue to delaminate. Thanks.
bowhunter007 New member Dec 2, 2012 #4 GMP said: Girard, Try HV electrical tape Click to expand... That's my favorite. Cheap, and it works.
Nick Gold Level Site Supporter Dec 3, 2012 #5 What kind of lube do you use ? I run bib mousse and duct tape works fine. I use truck tire lube and am generous with it.
F flybars New member Dec 3, 2012 #6 Thanks Glen. I recently used gorilla tape, but this HV stuff sounds like a better way to go. Should last a long time.
gasgasman Super Moderator Staff member Dec 3, 2012 #7 Nick said: What kind of lube do you use ? I run bib mousse and duct tape works fine. I use truck tire lube and am generous with it. Click to expand... I use the truck tire mounting lube also. It just seems to disolve the duct tape glue.
