s.c. national
If I got fifth at the National Enduro opener, I'd be bragging about it with a full race report.:)
congradulations to clay stuckey a 5th in the 45+A class nice job and all gas gas riders at the enduro
Thank you, Dennis. I don't think I have ever worked that hard for a 5th in my life. There are some fast old farts in the southeast!
Did you forget to fill the tank?
I had lots of gas left at the gas stop and at the end of the day.
I did go onto reserve in Sumter though.
There was lots of GGs at the National. I couldnt believe how many there were.
I went back through the results and counted 23 Gassers entered. That's something like 3% of the total entries. That sounds pretty low until you remember that the first national in 2010 had 3 GG's entered. Then it sounds better!
Clay
Great ride Clay.
Thanks for taking the time to answer my questions after the race. You looked like you'd been run through the ringer!
I had a rough day at the Sandlapper. Crashed 3 times in the first two sections - bent a radiator, bars and handgaurd. Had my jetting screwed up - it was so lean I was afriad I was doing damage so made a quick change between sections. Finally had to pull out at the c-cutoff with a flat front tire that I rode on for the last 1/2 of section 4. Now that was a rough bit of trail.
Here's some video: (warning: "R" rated due to langauge :p)
http://www.youtube.com/watch?v=bMrZm4mSta4
Not my proudest day.
2010 Sandlapper had 20 Huskys entered and 11 Gassers. This years event saw 23 Huskys...and 24 Gassers. :D
Rod I'm not sure how accurate those numbers are because I was looking through them and someone I know on a Husaberg was listed was HUS and someone I know was on a Husqvarna was also listed as HUS.
Great ride Clay.
Robby,
You're right! I was whipped. Sorry if I was incoherent. That last section kicked my behind.
Clay
