Sachs Aussie valve and stack
Simmo737
Gday
pictures depict 2011 ec300 valve, nice high flow valve and no peening.
stack is
23.1 (5)
22.1 (3)
20.1 (2)
18.1
16.1
14.1
12.3
washer
quite old school mx
I changed to
23.1 (2)
14.1
23.1
22.1 (3)
20.1 (2)
18.1
16.1
12.3
washer
removed 2 23.1 and created a mild two stage, seems to work, much less deflection, more traction supple plusher ride. No head shake on high shaft speed hits. need more time on more varying trails. I think it will benefit from a re spring to .46 (i'm 90kgs nude) and showed up the rear as needing dialling (i'll go to a 5.6 spring to start), which is usually a good sign that you are getting near a good setup
hope this helps maybe starts some people playing with that stack!
photos of the internals
