A adriano.ro New member Jun 23, 2016 #1 Is possible to find this breeders? Dimension of screw part seams to be so small then others.
S swazi_matt Active member Jul 10, 2017 #3 I took my fork caps to an engineering shop and got them to enlarge and tap the holes to kyb specs
S swazi_matt Active member Jul 10, 2017 #5 Rampart said: Does it means that you can't find bleeders for suchs? Click to expand... i suspect it will be difficult since the sachs bleed screw is very small so not much space to put a hole through the screw to make bleeders.
S swazi_matt Active member Jul 10, 2017 #6 Rampart said: Does it means that you can't find bleeders for suchs? Click to expand... it seems they may have changed the forks for 2011, as the description for these mentions that it also fits kyb and showa (which had larger bleed screws than my 2010 sachs) http://www.motocrosscenter.com/shop...r&utm_medium=Doofinder&utm_campaign=Doofinder
R Rampart New member Jul 10, 2017 #7 Looks like here they are https://ru.aliexpress.com/item/Susp...lgo_pvid=0a52ee5c-c5b7-4245-8356-42d0d852d118 And anyway, i guess it's not big deal to drill bigger hole in cap.
S swazi_matt Active member Jul 10, 2017 #8 I am pretty sure that the 2010's didn't have m5 bleed screws, i remember them being tiny
