Sachs rear shock Eye issues
siNN
Hi there,
Asking here as a last resort, I'm trying to fix the amount of play in my rear shock and have narrowed it down to the top mount.
Both the bolt and the spacers are worn and need replacing problem is I can't find the spacers anywhere. There's no part numbers, this is the internal rose joint:
http://www.splatshop.co.uk/shock-bearing-only-gasgas-ge12pw.html
If anyone could point me in the right direction that would be great.
This is the size of the original bushing:
You may be able to check with other manufacturers that use the SACHS shock.
i.e. BETA and Husqvarna.
