Guys with Sachs bikes, what is the dia of the upper and lower clamp areas of the fork? While I'm at it, are the new '11 Zokes the same and use the same clamps as the '04 - '08 Zokes? Thanks.
Thanks. So your saying that the lower clamp dia on both forks is the same dia? The '07 Zokes/lower clamps are 57mm, are the newer Zokes and Sachs larger then? 57mm seems VERY small for a 48mm fork.
I think it could be 59,3mm...
I have some sachs fork files with specs, but they are too big to upload here.
It's maybe from '09 sachs and it says that the upper clamp area diameter is 54mm and the lower clamp area diameter is 59,3mm.
