A damper seems necessary for those unexpected hits like a stray rock in the middle of a trail or maybe an angled log surprise. What settings do you use? I'm most curious about the high speed adjustment.
Here's where I'm at now:
LO Bottomed in then 1.5 turns out (12 clicks)
HI Topped out then 1.25 turns in
SWEEP 12 o'clock equal to 45 degrees (stock)
Does a damper have any value in the trees? I need to learn to stay away from saplings, they always do me in. I expect that the backbusters will move them aside but the saplings are unusually tough and throw me off course. Being old and needing a strong eyeglass prescription is frustrating. The only area that's in focus is directly ahead and I have difficulty determining whether I'll be tapping a small branch or if it will be one of those f'n saplings you could use to make a crossbow.
Does the HI speed setting do anything for tree strikes? The amount of leverage on the damper post must be incredible. Anyone set their HI speed damping too high? What is the result?
