motogroove
Looking for a torque spec.?
You will not find a torque setting for your studs, unlike other bikes.
You do not want to torque your studs.
You want to set the depth, leaving enough stud above the deck to hold the cylinder and the nut. This photo shows how the stud can be set too low. The stud in the photo is just about right, but note how much deeper it can go.
I learned this the hard way (months ago) - made a tool for torquing and used a YZ250 spec. Don't do what I did. You'll just end up backing them all out and setting the height.
HTH,
Dean
2001 xc300
HTH,
Dean
2001 xc300
