Shedding some weight EC300
Barbs
Hi all.
I have got a 2015 EC300 and its time to put it on a diet.
I am looking to loose some weight on it so I am thinking ill remove the E-start, battery and associated wiring. When removing the starter I should be able to simply replace the ignition cover with the non E-start version is that correct?
Any other ideas on how I should strip some weight off the bike?
Thanks in advance.
The ignition cover will swap over.
Most of the weight is in the swingarm, frame, and engine.
Weight can be saved on the rear spring (use titanium ), rear sprocket and chain (use non o-ring), thinner inner tubes, and add only enough fuel for the section you're riding.
No worries cheers mate. It is pretty good now anyway but thought I never use the E-start anyway I may as well remove it.
