Shift shaft play
A few mm sounds a little high to me but it should not be an issue as long as it shifts ok. Do you have the thick metal core inner clutch cover gasket? The inner clutch cover is the inward stop for the shift shaft.
Thanks for your replay, I'm unsure if I have for 2 reasons
A) I have never opened the bottom end
B) I'm not very experienced mechanically:o, but I'm learning!!
