shift under load
fullthrottle
hi guys just wondering if anyone else has the same problem.
when i am in a race situation that requires me to shift up without letting off the throttle but using the clutch it wont shift unless i back the throttle off abit, the bike has always been like this since new i have tried motul and maxima g/box oils. On my 125 i could just hold the throttle pined and use the clutch and shift. i feel like i am losing quite abit of time over a 6 hour event just because of this. I dont ride like this everywere but sometimes its required if ya are hearing me
any ideas???
keep trying different g/box oils?? or are they all like this??
The 125 probably has under-cut transmission gears. This allows better "meshing" of the gears under a load.
There are shops that can perform that mod for you.
Trying different fluids may be your best and cheapest option.
i have the same problem on my new ec200 will not flat change at all...using motorex gear oil but will also try belray and let you know....hand built, blue printed engines should be better otherwise we would all just buy a japper like most other people
