I'm going to have a stock set of shiver forks available from my 05 fse450. Will upper and lower clamp and such will be included. Replacing them with a pair of ohlins.
Make me an offer.
spd,
I have an 03 FSE with Ohlins, and I have a 04 300 with Shivers. The axles are completely different. The Ohlins axle is a much smaller diameter. I didn't swap forks, because I didn't want to swap wheels as well.
Mike.
Not sure about the Olins axle dia.(probably 20mm) but seems like you could just switch out the bearings for ones with the same OD but a smaller ID. You would also need to downsize the Dia of the internal wheel spacer.
That's what I'd do.
Tony might be on to something. I'll take a better look at the hubs and berings.
Mike.
