I don't know if this is exactly the answer you are looking for but I have used a 1999 Kawasaki KX 250 KYB shock on my older Gas Gassers. I had one on a 2001 300 and I believe it would have fit my 2007 as they "looked" the same. Those should be a similar shock to the 2011. The KX shock is a little bit shorter so I got some shorter (I think?) dog bone links for the suspension. Frankly, the KX shock worked much better than the stock Ohlins. I think the '99 KX shocks work on '97-'02 KXs (I think 2003 KXs, too, but I have not tried it yet). Please note: You cannot use KX shock parts in the stock GG shock.
