If it's the same as my '13 then any lever that will fit any of the bike in the picture will work for the brake.
For the clutch I just ordered a Zeta lever.
Here are the Zeta part numbers for both in a folding lever.
Brake : ZE41-3206 (Nissin master cylinder)
Clutch : ZE42-3185 (AJP clutch lever, the same with GAS GAS trial)
I'm not sure if they are considered shorty or not.
I have a Moose Racing shorty clutch lever that is listed for GG up to 2007 but it looks like an exact fit for my 2014 300. If you wish, I can install the lever and tell you if the lever fits properly. You can search on part number 0613-0016 or 1CDGS17...
Eric
A hacksaw and file do wonders. Free too if you have the tools already.
Next month i'll be in the market to buy some shorty levers.
What brands/models do you guys have on your bikes ? Thanks in advance
p.s. the bike is EC300 '14 model
I was able to successfully install on my 2014 300E the Moose shorty clutch lever as described in my prior post. Please note, I did not use the stock clutch adjustment screw as I was trying for a quick check. Instead, I used an S3 adjustment screw which has a larger head allowing it to be adjusted with fingers. This screw interfered with the large switch assembly requiring some additional adjustment. In sum: The Moose shorty clutch lever works, it is inexpensive, and only requires a little adjustment if you are using an S3 adjustment screw. Good luck finding the lever in Europe! If you do, you will be happy!
Eric
