Silencer Grommets
HydroDog
Does anybody have a line on where to buy new grommets for FMF silencers?
Mine are about junk and need replacing. I called FMF and they do not sell them seperate, they only come with a new silencer:mad:. I was looking at McMaster-Carr and they do not have any that are a close match.
Any ideas?
Or, after I thought about it, the mounting grommits?
BE250026005 - 15-SILENTBLOCK SILENCER
From your dealer.
eff I believe he is talking about the rubber grommets that you put the bolt through to mount the silencer to the subframe
I got a bigger problem ...
my grommets are fine ... but the hole they go into has worn into a bigger size so now the grommets roll around inside the hole and the pipe fits kind of loose, I don't see this getting anything but worse. Only solution is a new silencer or alu welding and machining new holes. which would probably cost the same as a new silencer ...
Thanks for tip and the part#
I guess I should have made it a little more clear.
I was talking about the mounting grommets. I have the same problem also of the mounting holes being worn out on the silencer but I was going to weld them up and machine them back to size.
