Speedo adj from 21" to 17"?
cal_tony
The speedo section of my 2004 FSE manual is confusing to say the least.
There is a mention of of getting ("a 00") somehow and then you are in the rolling radius mode and you can trim the speed to run fast or slow. From a-25" to +25".
But they advise you not to change it.
Other than the the tech that wrote that page, does anyone understand how to make the change. My read is that there is no simple method to change from 21" to 17", but by adjusting the trim it can sort of be changed.:confused:
Anybody know how to get to the "a 00" screen and once there how do you make the adjustments?
My 21" tire has a 27" dia and my 17 has a 23.5" dia. So if I get into the trim screen, would I just change the a00 to a -3.....?
Tony
My speedo is the stock device found on the 2004 450 Fse. The manual I was referring to was the owners manual that came with the bike.
Is there a separate manual for this device somewhere? Anybody know where there might be more info on the device? How about in the later GG years. Do they still use the same device and are their manuals more descriptive of the products use.
The device you mentioned is something that a lot of DRZ owners switch over to and although I still haven't put on mine, if I don't find an answer to my problem, I might very well get one for my GG.
Tony
