As a comparison, I am at 117 kg (~260 lbs) fully geared, I run K 0.48 fork springs and 62 N/mm rear spring. Note that this is on the heavier FSE, which have 54N/mm rear spring stock, as opposed to the 300 which has 52 N/mm.
Fitted the springs tonight and I was surprised how much preload the FSR needed with a 6Nm to give 35mm static.
If you don't revalve you might as well leave it stock and try to compensate with the adjustment knobs.
Rear spring?
Where did you get it from?
