Starter flywheel removal and nut question
andykr87
Ive removed my estart system almost completly now. I bought a plastic ignition cover to replace the aluminum stocker that the starter mounted to. The flywheel was hitting the new cover so i popped the nut of the ignition and removed the flywheel. Question is, do i need to order a different nut to hold my ignition on or can the stepped nut be used. If anybody has a stock nut ill buy it from you if thats what i need. GMP, im sure youll read this, do you know what im talking about? Thanks guys for any help!!!
I think you mean the ring gear on the actual flywheel, correct? I've never seen the start parts, but I imagine the stepped nut is for centering this ring gear. If it bottoms out on the flywheel and holds it, and does not hit the cover you will be fine.
Sent from my C771 using Tapatalk 2
I called mark at gofasters this morn. What you described is spot on my thinking was what you said but he said i need the correct nut and washer to do this right so im goin off what he says. Thanks for your reply as always man.
