Starter sprocket bolt
kiwigasgas
Got all the bits together to fit a starter to my older gas gas, only bit i couldn't find was the starter nut to bolt the gear wheel to the flywheel on the 12 - 13 model.
Anyone have one off that they could measure up the dimensions for me and ill turn one up. Be easier than trying to measure everything as i guess it clamps up on the gear wheel and the flywheel at the same time, not too sure
I can't speak for the newer machines but on the 2011 the ring gear holes fit over the rivets on the flywheel. The nut simply keeps the ring gear against the flywheel. The nut is longer to reach the crank threads. Hopefully someone can measure up a 12 or 13 model for you. I didn't take notes when I had mine off.
yep thats the one, it fits nice and tight over the flywheel rivets, just need the longer bolt. Maybe ill try and measure it and make one up
