You could put in a longer rod if you made up an appropriate spacer to raise the cylinder up however much longer the rod is over stock, however I cant think of an advantage of doing that, other than to change port timing??
The rod length doesnt determine stroke length, the crank offset does. So a longer rod with the same crank doesnt increase capacity, it just moves it to a different portion of the cylinder.
