studded tires
12 psi sounds reasonable. I tend to use mousse, according to Michelin their mousses are similar to 12-13 psi or thereabout.
Sent from my GT-I9505 using Tapatalk
What kind of tires? If your running trelles you don't need mousses just use a heavy duty tube. The sidewall is stiff enough to run as low as you want. I run 8psi in the rear and have never had a flat in 6 years. I run a new set every yeAr thoughto keep that sidewall stiffness. These came in the mail on Friday!!
just picked up a used set of trelly knock offs same studs and tire compound is the same. I run heavy tubes just took a test ride just wasn't sure if you would run a high pressure to help the stud dig in? I have it at 12psi now. It's been years since I have ran in the winter I am really looking forward to it.
