SpeedyManiac
Hi guys,
I'm taking an introduction to manual machining class (Milling machine, lathe and drill press) where we get to choose our own project. I had my first class on saturday and it was great. Now there's 42 hours of machining time left. I have a couple ideas for projects so far:
1) Slave Cylinder Guard/Case Saver. I think this would be somewhat difficult to make on a manual mill, geometry dependent. Bonus is it would be made from aluminum which would be fairly easy to machine.
2) Bar mounts with integrated handguard mounts. These would be similar to the Fastway mounts. I think this would be a pretty straight forward part to make.
3) Front axle pull. Used to make pulling the front axle out easier. I'm not quite sure how I'd make one as it's round with a lever sticking off it.
4) Kickstand and kickstand mount. The stock GasGas stand is a PITA as it automatically retracts, and changing the mount location results in broken springs. I'm beginning to think this would be ideal as it incorporates the lathe (for the kickstand) and the mill (for the mount on the frame).
5) I've also considered making a new front or rear axle with integrated axle pull if I do the bar mounts or case saver as I still need a project for the lathe in that case.
I'm limited to either aluminum (T6-6061 or 7075), steel or maybe stainless steel for materials. Designing the parts isn't an issue (I'm in 4th year MecE with access to Pro/E and Solidworks for CAD), but I need to get the drawings to my instructor before next Saturday, with earlier being better than later. Any other ideas on projects, or ideas for these ones? Thanks.
