Well there are plenty of good greases out there but after reading in the Suspesion forum about the Jet-Lube Moly Paste I contacted Jet-Lube about using it in wheel bearings. His response was no, it's to thick but in the linkage, swingarm and steering head applications I described to him it would be fine and a good choice.
His recommendation below for our wheel bearings was this Extreme Service Multi Service Grease.......read the pdf file in the attached link.
We have a products called Alco-EP 73 plus, which Is used in the boat trailer wheel bearing application. This grease is also used for subsea equipment in the oilfield industry. We also supply some of the NHRA teams which use the grease a bearing / torque plate assembly lube in the differential or rear end of the dragsters and funny cars.
