Throttle Cable Crossover
Ed Ventura
I seem to remember from my last GG that a ktm thottle cable will work. Same carb and pretty sure it it is the same domino throttle tube.
Yes/No?
Thanks ED
I just bought the longer cable from GoFasters and was done with it.
The carb is PWK and the throttle is Domino, but I think the only concern (other than length) would be if the cable guide at the top of the throttle cap has the curve so it clears the tank.
I got a honda cr cable a year or so back. I was looking for something bit longer. Iirc, it was not any longer and it did not have the bend on it for the tank where it went into the carb. I ran it a bit and it worked but it was the same length as the stocker and did not get along with the tank. I'd get the go fasters one, I've been told motion pro make a longer one but make sure they know that. I ordered one from them and it was the same length as the stocker. I've got a very little used stock throttle cable I'd be happy to unload cheap!! Or that honda cr cable!!!
06 de 300 btw
What is the part number from Motion Pro?
I think they are custom ordered by GoFasters. I'm sure Mark and Steve are busy with the ISDE, but hopefully they will correct me if I'm wrong as soon as they can.
A little off topic, but do you guys know if there is a crossowerpart for the clutch handle on ´07 450fse??
