To hone or not the cylinder?
adriano.ro
First top end refresh on this bike,ec 250r 2014,has around 130 hours and still strong on power,start super easy. But is time for new piston,and with this event I clean really good power valve. Is really necessary to hone the cylinder or he need a good cleaning,(I mean for those hours )?
+1
Measure the old rings for giggles. If you're using good oil you might be surprised.
I use only the best oil on the market,and I try to find best jetting to not make the engine to suffer ,the compression was almost like new, 170 psi!? For those reasons I would like to clean up and not to hone the cylinder .
If you melt a piston you can use muriatic acid to remove the aluminum from the Nikasil. If the Nikasil is scratched then you need that replaced.
Check that cylinder for a ridge at the top. If the ridge is significant I would be worried about catching the top ring.
I can feel it with the finger but is small enough. And I will use same base gasket 0.5mm.
