Torque Specs EC 125 2005
Noobi06
Im back like always. Today im asking for torque specs.
1. What are the torque spec of the bolts holding the front axle? That are clamping the axle to the fork.
2. What are the torque specs for A, B and C. There are gonna be nuts there.
From the 2015 user's manual:
Linkage bolt M14x110 100NM (that would be your A B and C)
Swingarm bolt M14 80NM
General:
M4 nuts and bolts 3NM
M5 nuts and bolts 6NM
M6 nuts and bolts 10NM
M8 nuts and bolts 25NM
M10 nuts and bolts 45NM
The complete list for the chassis:
Steering nut M24 40NM
Rear shock bolt M10x50 45NM
Brake disc bolt M6x14 12Nm
Front axle bolt M20 50NM
Brake caliper bolt M8x30 30NM
Engine mount bolt M10x118 40NM
Rear sprocket bolt M8x30 30NM
Subframe bolt M8x50 25NM
Brake banjo bolt - 6NM
Upper clamp bolt M7x30 15NM
Lower clamp bolt M7x30 11NM
Spokes - 1,5NM
Rear axle nut M20 100NM
Rear brake pedal bolt M8x45 25NM
Oh so the linkage bolt is all 3 holes?
According to my manual, there is a linkage screw that should be at 81 nm.
There is a rocker screw also at 81 nm.
Then theres a suspension flange screw at 29nm.
Lastly theres also a rear shock bolt at 39nm.
Can you link A, B and C to those screws? I dont know what is what. I do not know the names. Please state what A, B and C is and the names and the torque values according to what i said ^up^ etc.
Also, side question, what is the Transmission rear plate nut. its supposed to be torqued at 29 nm.
thanks in advance Anders. ur always my help :)))))))))
