richo,
I've had all three forks apart (Ohlins, Zokes, WPs). Compression or base valve removal and springs are the same on any fork, thats the easy part. Revalve is not just compression however, and an oil change requires cartridge bleeding like any fork. If you find it easy to bleed the Ohlins cartridge, you either have the tool, or did not get all the air out. I suggest you give Les a call and ask him, he did a lot of Cannondales during their breif history.
I'm not saying the Ohlins fork is bad, it is a very high quality component. What I am saying is that for an average rider/racer who does his own work its a hassle and expense thats not worth it.
What don't you like about the Zokes? Make sure that lower clamp is not too tight, 12Nm. They could use a little shim tweaking but are not bad stock.
