Tubliss/Goldentyre gt216x
It should work v well but you will need to be careful of punctures. I have not run this exact setup but I have run tubliss with Mitas green stripe and will again
The green Mitas and the gummy (I believe) are designed to use a mousse so they have a thinner carcasse so are easier to puncture
Yeah that's what I'm afraid of. I have some buddies that have ran it with a tube at 8psi just fine. So we'll see. Going to install this week.
Speaking of Mitas ef07...have you ran the yellow stripe?
I run Mitas C18 green stripe with T-lock* and 7 psi at the rear. Works very well for me (old & slow), but my much faster friend had problems with torn sidetall when riding fast thru the rocks.
*T-lock is a Swedish competitor of Tubliss.
I Have just ordered Tubliss for the front, going to try it with Mitas C19 green stripe.
I haven't tried any of the ef07 I was about to try the yellow stripe but it seemed that the c18 was more suitable for my terrain so stuck with it. I know there are some guys running the ef07 double green with tubliss but you need to be rich for that because they only last about a day - granted it is a day of idling up cliffs like Spider-Man
Ps here is someone using tubliss and golden tire http://www.ktmforum.co.uk/off-road-enduro/1127385-tubliss-supply-30.html
http://enduro.live/wp-content/uploads/2016/03/graham_jarvis_gforce_-78.jpg
I won't go back to tubes having tried Tubliss with MC12 Mich They seem to be staying sharp longer for some reason, its quite noticeable.
