Update kit Headlight Assembly ???
Zrt1200
Well I received a big box from Motocrosscenter.com today and I am putting the new headlight assembly together but I need to know if this is the correct order and if I need to drill a hole through the headlight where the holes are on the metal tab. It would have been nice if there was at least some instructions or pics of it assembled. The headlight is supposed to be the 2015 model design.
Do I have the headlight adjustment screw with spring in the correct order with flat washers??
And do I need to drill a cross hole through the headlight to bolt the metal bracket on. It came with a long enough screw do to that??
Would any one have a pic of the back side of there's?? Thanks guys in advance.
