Is the upper shock mount pressed together? I have an 02 and at a minimum it needs new orings between the bushings and the shock body possibly the heim joint that is supposedly inside as well.
I took it apart last night. For those of you who are curious it is a heim joint, mine is in nice shape, with bushings pressed in from either side. The orings probably were fine, they will be new when I reassemble.
