angrytim
I did my 1st Enduro w/ my Watchdog computer this past weekend. I need a little help since I burned 2 checks.
Question 1: Reset at 32.4 to 35.9 (3.5)
You come into a reset and your mileage is off just a bit. You use the up arrow to change your mileage. Do you
Change it to 32.4 or 35.9. It seems to me since I programmed the reset, I would change it to 32.4. Will I automatically
see a countdown to let me know when I should leave? I was on time, but I didn’t see a countdown and had to manually
figure out when I should leave.
Question 2: Pause 12 Min. at 20
Same question, should I see a countdown as to when I should leave if my mileage is correct. I didn’t.
I figure I’m doing something wrong. Any help is appreciated.
