We are stumped a little ??
101racing
OK here goes, I have a 08 300 EC with LTR jetting kit.It runs good ,has decent bottom and a strong mid range hit . My son just picked up a 06 300 DE that was a repo out of New Hampshire. It has a little time on it and appears to be stock but when we finally got it all checked over and fired it up we were very surprised at the power delivery . THIS BIKE IS AN ANIMAL!!!! The first thing that I thought was that it had the RB carb and head mod but we looked through the carburator and can't see any divider plate . It has the stock 06 pipe. The needle is bronz colored and the number has been ground off. We are stumped and would love to get the 08 to run this good. Did GG change the port timing from 06 to 08 ?? Could the 06 have a different CDI box ?? All we know is the 06 builds loads of arm stretching torque right off the bottom and keeps right on pullin through the mid range and upper end. Has anyone ever played with the governor spring on the power valve ?? Any suggestions would be greatly appreciated.
Is the '08 a full "EC" with the 2K3 ignition? The DE has the 2K2.
Check to see what locations the wires leave the ignition cover. If at 10:00 then 2K2, if at 2:00 then 2K3.
The 08 and the 06 has the 2k2 ignition. The only obvious difference is the 08 has the FMF pipe and the 06 pipe has GasGas stamped on the side of it.
3 things that may be different
Jetting - sounds like an LTR needle in the '06
Ignition
Compression
I say, if it is an animal just off idle, you have a higher compression head on the '06. It's an easy swap to test it out on the '08 sometime. The resom I say this is that my '05 was whimpy off idle compared to my '00 with the higher compression head. With the RB cut head, the '05 became an animal that I tamed with different jetting a gearing.
Even with the jetting dialed in you will have a big difference due to the pipe.
I have used the FMF, Doma and stock GG pipes. The FMF pipe signs off very early. The Doma on my '01 XC300 and the stock GG pipe on my '06 EC300 are nearly identical. The stock GG pipe and Doma are much smoother and have much more top end power than the FMF.
My real world dyno is a hill. On a steep dirt hill, my '01 XC300 with the FMF was only able to pull 3rd gear at a moderately high RPM. When I put on the Doma pipe, I could pull 4th gear screaming at a much higher RPM than with the FMF pipe in 3rd gear. It was a huge difference.
The Doma & stock GG pipe are much better than the FMF Gnarly for my woods trail riding and open sand riding.
Try swapping pipes and see what happens.
The 08 with the stock FMF pipe doesn't have as much bottom as the the 06 with the stock GG pipe. I suspect maybe it has the RB design head is the biggest reason for the huge bottom end torque :confused: The needle is a mystery also. I'm sending off my head and carb on the 08 to have RB work his magic and then maybe it will run as good as the 06.
The RB designs head work will make a big difference on the low end torque. It also improves fuel efficiency.
The RB designs carb mod works well to clean up the partial (0 to 1/2) throttle operation.
After you test the RB designs mods, try swapping the pipes and see how that affects performance. I expect that the pipe swap will make the biggest difference on the top end.
The older FMF pipes sucked. Like Erik K stated the Doma or the older OEM GG pipes are much better all around. From the sounds of it FMF has not made a Doma clone and we are getting the same old pipe. MY 02 300 with the 06 oem pipe, 250 ignition, no reed spacer and the LTR kit flat out hauls. Instant throttle response that pulls to a decent overrev. I am however looking for ways to improve the topend on my bike.
Paul B
Why if the Gas Gas pipe works so well (and I read that allot) and seems to be made of decent heavy material do we continue to get the FMF pipes? Seems to me the stock spec euro GG pipes should come standard.....and the 2K3 as well IMHO but that's another topic for discussion.
Skidad in MA
Skidad in MA
I wonder if keeping everything the same would make the price come down...
According to Steve at GoFasters the new FMF pipe is a Doma copy.To look at the stock GG 06 pipe versus the FMF 08 stock pipe they look very close to the same configuration.
The difference in ignitions ( ie 200 250 300 ) seems to be a mystery also.
I'm sure its cheaper to import the bike sans pipe and install the made in USA FMF. An OEM GG pipe lists for close to $400.:eek:
Ok we have pulled every rabbit out of the hat that we can think of on this one.We have the RB head and carb on the 08. The 06 will out pull the 08 off the bottom and lower mid . The 08 runs good and is very ridable but the 06 has unbelievable torque and power off the bottom. We changed pipes,CDI's,ignition timing nothing has brought the 08 up to the 06. We are going to open the 06 up to see if there has been port work and or check the port timing difference. Also power valve initial height and governor spring. Curiosity is killing us !!!
Did you do a compression test on the '06 and compare it to the '08 ?
Carb (with jetting) between the two?
Reed block swap (no spacer)?
Make sure the '08 PV is adjusted correctly, that is the plate rests on the stop bolt at idle (will vibrate off slightly from exhaust pulses). I had an '03 250 that was a little flat and found this helped.
Finally cylinders. Also, awhile back like pre '01 I beleive, the 300 cranks were not stuffed, only the 250s. Since then they all should be stuffed, and its easy to see if the cylinder is off.
stuffed???
cyclinder off??
explain please .....
Correct me if i am wrong but stuffing the crank cases you are making the relation ship between the crank and cases tighter creating a better flow.
The stuffers increase the "compression" on the piston's down stroke.
This speeds up the fuel mixture through the ports.
Have you tried simply swaping the carbs and heads between the 2 bikes? The RB head work turned my '05 into an animal using an LTR needle with a #8 slide. I had to drop a tooth on the rear sprocket, go back to a #7 slide.
We just took the pipes off of both bikes and looked at the power valve differences and there is a definite difference. The 08 has some ears that drop down on both sides to make it more oval shaped . The 06 is straight across and appears to be less restrictive. The initial height adjustment doesn't look to be too much different using inside calipers to measure. Without taking the heads off both bikes we won't know anymore. The power valve governor spring seems to feel the same. If the 06 is completely stock then GasGas has made an attempt to soften up the hit on the 08. JMHO.
