Adjustable pv's rock.
I just bought an 2002 xc 250 in close to mint shape, around 25 hrs. But my older ride is a ATK lq 260 with a Rotax in it.
The rotax used has an adjustable power valve. I must say it is one of the cooler things about the bike. The engine is great. Not a powerhouse but for my lightweight, it goes well. Ultimately reliable. In the spring I crank the PV spring tension tighter to open later, and its electric. As it dries towards summer I set it mid depending on traction required, if it's hard, I just set her to open earlier.
Why they all don't do this I have no Idea. Sounds like a decent way to take the edge off of those XC's,DE's and MC's people out here in the East are running. Cheaper than an expanded pv cover/Throttle Cam/Flywheel weight/ EC ignition combo. And once installed way easier to go back and forth. Simply bend over and crank the screw.
Anyone running one? How easy to install?
I am asshat
