What fender with Yamaha KYB SSS forks??
nknudsen
I'm gathering parts to do the Yamaha fork conversion on my EC250. What fender do most use when converting to KYB forks? Has anyone modified the lower triple clamp to mount the 2011 type fender? Pictures are welcome! Thanks!
Noah
I'll be posting up my conversion here pretty soon.
Since you asked, here's what I did.
I ground down the two bolt lugs on the front of the 3X clamp. Took a die (8mmx 1.25) and cut threads on the two vertical pins on the clamp.
I drilled two new holes in the GG fender-1/2" aft of the OEM holes. Then I made an L bracket to mount the front of the fender to the Yamaha clamp. I reused the two front holes in the GG fender.
Great idea! Thanks for the tip.
You're welcome.
Took me 2hrs to get this done. Most of that was trying different things to make the OEM GG fender work. The bottom of the headlight is moved foward about an inch. No big deal.
Is your tire fairly centered in the arch of the fender with this mount? Would you've done anything different?
i just bored my gas gas upper triple clamp to the size of the kyb fork on my 2010 sachs equipped that way i could retain my factory steering stops. with out the the stops you can very easily bend the upper fork tube in a wreck.
The arch looks good. Does not look like the tire would rub.
The easiest option would be to use a YZ front fender.
Maintaining fast steering means maintaining the stock offset. The YZ parts do this. Mix and match and you lose it.
the sachs fork lower is the same size as the kyb. the upper is 70 thousands to small a simple bore job made it very easy the caliper was even the same the bracket was the only difference. i had these forks revalved when the where on my yz250f and they where incredible on that bike on the gasgas it is the most improvement i have ever experienced in 20 years of riding offroad the kyb forks made a hard to ride bike in to a offroad weapon.
the sachs fork lower is the same size as the kyb. the upper is 70 thousands to small a simple bore job made it very easy the caliper was even the same the bracket was the only difference. i had these forks revalved when the where on my yz250f and they where incredible on that bike on the gasgas it is the most improvement i have ever experenced in 20 years of riding offroad these forks make a hard to ride bike in to a offroad weapon.
thanks, still thinking about this, but if i see a good bargain i may give it a try
Noah
For the amount of work I just bolted up a white Yamaha front fender.
The door stops were a great Idea
