Wheel Sets To Fit GasGas?
smallpuffydog
Bronze Level Site Supporter
I am trying to find out which wheelsets (if any) from other manufacturers will fit a GasGas. Specifically a 2007 EC300.
I really dont want to have to mess around with anything more than modifications to the wheel spacers.
Thanks,
Matthew
My friend has a KX wheel on the rear of his 01xc300. I think it only required spacer modification which is also the case when going from a 01 model gasser to an 07 model.
I run a set of 2003 stock GasGas wheels with the U-rims on my 2011. Look for a part out bike and grab the wheels. My wheels are on their 3rd bike and are by far more resilient than the newer excel wheels in my opinion. All you need is the newer seals and bearings and larger diameter spacer for the front wheel.
I would be willing to bet that the 2012's are still using the same swing arm, forks, clamps and axles that they used on the 2011's. If so, they would most certainly fit.
