Where's The Lighting System Fuse?!!!
There is a fuse block under the seat.
The wiring diagram has it as 15A and labeled "F1".
The troubleshooting guide mentions removing the "rear light cover" - anyone's guess....
Know which fuse it is??
I've gone over the wiring diagram and found out "where" it should be but still can't...:confused:
Anyone know the exact location of the lighting system fuse?
Thanks,
Jeff
if the fuse box is under the seat, why dont you take them out one at a time, and visually check them, if the arent clear, use a continuety tester.
Either behind the right side number plate or behind the headlight. Thats the only ones i've ever seen.
Isn't the lights fuse located INSIDE the starter relay? I might be mistaken, but i think its under the cap of the starter relay.
