Which airfilter cage? ('07 FSR450)
Mikesbaron
I just picked up and FSR450, it didn't have the air filter cage. I'm wondering if there are other model cages that will fit?
I'm also concerned about how this OEM set up does not have any way to securely keep the filter in place without it shifting or rotating around the mounting surface opening. Is there a retrofit or other model filter setup that is more secure?
Or am I just going to have to order an oem filter cage in deal with it?
07-11 use the same cage there is a spring device that holds it in as far as I now is stock is the only option
I've been to every OEM Gas Gas order site I can find and can't find anything from Gas Gas here in America.
There has to be another item from a Jap bike that can match up.
