I was curious if anyone using Moose or IMS pegs in the normal setting could tell me how much lower they are vs. stock. I assume they would be a bit lower because of the way the stock pegs stick up so high compared to the way most pegs are made.
Anyone knows if KTM's foot pegs can be installed on GG ?[/QUOTE
I have not tried the stock KTM pegs but the Fastways I am using are for KTM. I just had to grind a little of of the tube and they fit fine.
One option is to use the stock GG pegs. Cut the "extention" tube off each peg, weld it onto the top instead of the bottom (where you just removed it from) and then swap the pegs side to side. This gives you a lower and slightly rearward position from stock. I got some Yamaha yzf pegs to try this on, but found the mount is central on those pegs, not offset as on the GG, so only a couple of mm difference could be obtained with the yzf pegs.
Cutting/re welding the extension tube makes sense
But why move the pegs to the opposite side? I went and looked at the bike but a side-to-side switch is not making sense (I am blonde)
J
It's the springs that get swapped side to side. The pegs stay where they are. Because the pin tube is being flipped to the underside of the peg the springs have to swap sides. A buddy of mine has done the lowered peg mod on his bike.
