wild rear hubs crossover
Just bought a Honda 05 Trx 450 hub?!
This honda stock unit is actually made of steel rather than the stock GG aliminum unit. Part was 44.00 off the shelt at my local honda dealer. It's still a 110mm bolt pattern. Can't wait to get off work and try it out. It looks like using the honda hub I won't need the two spacers GG had installed to make up the extra axle length. I'll post more tonight after I fit it up and check the splines to fit.
Ohh I almost forgot this is for my 03 GG wild 300 HP.
I used a 2005 Honda TRX 450 rear hub and its much better than the stock unit. You wont need one of the spacers that are stock with the Gas Gas Hub FYI. My part costed about 46.00 from local store.
