Wiring question EC 300 2010
mmarco78
Hi all, I am rewiring my 2010 EC 300 with a simplified wiring, and I am all good regarding lights, regulator etc.
However, the previous wiring was one huge mess, and now I am left with three loose wires coming from the CDI, as per attached picture:
White/blue
Black/yellow
Black/white striped
As per the wiring diagram I have:
white/blue should go to the pin of the spark plug coil
black/yellow should go to the ground switch (engine stop)
black/white seems to go to the multifunction instrument, probably as a rev meter, so I can just blank it off/tape it, as i do not use any dashboard as per now.
Can you please confirm?
Thank you all in advance for helping out!
Solved. White and blue goes to coil, black and yellow goes to kill switch, black and white is cdi ground and goes to frame.
