wp or zokes diameter at clamps?
Cruiser
Just real quick,, I know its here somewhere but cant seem to find it in the search,, what are the diameter for the wp and zoke forks,, I believe they are the same,, now I might have a set off a husky to use on my old 97 250 and I need to know if I'm going to have clamp issues or I can use GG clamps?
Thanks,
Steve
upside down units? I was curious and measured mine and my kids last night, there was 1mm differance but I can't remember which one was larger or what they measured. I will check tonight and reply back if someone else doesn't answer your question.
Jeff
'00 XC250 43mm WP's
'04 EC250 45mm Zoke's
I'm sorry,, yes inverted,, I'm ditching the conventional 45's and going inverted on the 97.. I need to be sure the forks I'm looking at would fit.. I have several sets I'm looking at.. Mostly ktm forks as gasgas forks are a little harder to come by..
Thanks,
Steve
Yes, the inverted WP 43's and Shiver 45's are the same. bottom clamp diameter is 57mm, top clamp diameter is 54mm. Guess I wasn't being too careful when I measured last night (and said there was 1mm differance).
Good luck with your changeover!
Jeff.
ps, I love the Zokes on my kids bike!
Thanks,, Now the question,, The ohlins top is the same but what is the bottom?? I have a good deal on zokes from a husky,, they are 54top and 58 bottom.. So do it the dirty way and cut 1 more mm out of the bottom clamps? or find other bottoms,, or do the fork bodies have enough to spin down 1 mm? The husky axle is real close to the gg axle.. Might even be closer than the ktm axle.. so do the 43wp off a ktm and play with axle issues or go with the husky and have clamp issues??
Decisions
