Did you ever find a replacement or alternative to your fuel pump? Mine went out and would love some advise as I am having issues with locating something. Please advise.
Do a search on here. If I remember correctly the pump crosses over to an off the shelf part used in the automotive trades. Pull your pump and on the body of the pump itself there will be a series of numbers. Do a google search on them and you may end up with a Bosch part you can pick up at a napa auto parts. The Ktm 990's fuel pump can be and just about every other one out there. In fact the pump most likely is the same one as the Ktm one.
Cruiser, thanks so very much. I will get on this asap, only problem is that once I have this my winter project will be done before winter starts. First world problems suck. Thanks again.
