CDBiker220
Hi, having a very bad time with a used 07 EC300. First found the right side crank bearing to be loose in the case, had case sleeved and replaced bearing. Now its loose again, found out the shaft the clutch rides on is bent, and worked the gear loose on the clutch basket while hammering the crank bearing loose in the case. So im trying to find any of these parts...right side case half, gearbox shaft that the clutch rides on, and possibly clutch basket. I believe 05 250/300 and up cases will work, I imagine the clutch shaft is the same for almost all years. Not sure about clutch. let me know if you have anything. This was a six days bike and apparently had a hard life. Thanks for any help.
